processor for new build?
stainremover
i'm getting a new build before school starts. all i'm missing is a chip, don't know what to go with. my budget is about ~180 for the proc. i'm thinking either q6600 or e8400 but any suggestions much appreciated.
current part list:
asrock x38turbotwins-wifi
2x1gb ddr2 1066
2x3870
will run 4 drives in a raid5 through my ich9r
gaming is light (the 3870s are for excessiveness). i mostly use my computer for labs - e.g. 1gb of data loaded into memory at once for processing. i like to multitask. i spend a lot of time waiting with simulations in the background, so i'll surf the web or go torrent stuff, things like that.
Lots of multitasking and data crunching sounds like quad-core territory to me, and the Q6600 is the best value there. Are you planning to overclock? The Q6600 overclocks very well if you have a half-decent aftermarket cooler; 3GHz is trivial and many get to 3.6GHz.
I can get 3.2 easily with mine, i have not tried to go higher. I have the Tuniq Tower and keeps it very cool. I am sure my cast with 3 120m fan's blowing on the mobo train does not hurt either :p
For the kinds of tasks you're doing, a quad would be right up your alley. I doubt you'd be able to run heavy simulations at the same time as general-purpose usage with a dual-core, even a fast one.
Also, a few comments about the rest of the build. Regarding the video cards, I suggest you go with a single 4850 instead of the two 3870s and save yourself a couple of bucks, since a single 4850 is around the same speed (unless you're buying the second card for folding, in which case the two 3870s would probably do better). Also, it would be a good idea to go with a cheaper P45 board instead of that ASRock X38, since you would save another few bucks and you'd probably get better overclocking out of it as well.
i got the asrock board for $95 from a fellow off the forums. i'll take your suggestion on the 4850. probably a good point. any recommendations on one with a good cooler? i hear the stock one is balls.
The Xigmatek HDT-S1283 is the best bang-for-buck cooler. It can generally be found for $30-40, and sometimes less if there's a rebate going on.
Get the Q6600, my 1 year old son overclocked to 3.2Ghz for me on accident and its bullit proof.
If you've got the money the Q9550 is uber sexy but no way best bang for your buck eheh
a used Q6600 is hard to beat for performance vs. price
