Im looking for Opinions on what the most effective CPU Fans are. Not necessarly the ones that look the best but more or less the ones that work the best. Anyone have any Ideas?
I"ve had great luck with the Alphas and Zalman HSF units.
I prefer the Alpha because you can use whatever 80mm fan you want on top for your custom cooling needs... plus you can add a nice custom grille over your 80mm if you want to...
