Jakalwarrior
- Aug 6, 2005
Ok im sure most of us know peltier devices can generate electricity when you pass heat through it. Or it can move heat when you pass power through. You couldnt feasibly gain much power from a modern chip though because the insulating effect of the actual device would be too much (your chip would fry).
here is something new I ran across while browsing around in old tech news.
"When heat is injected, the heat builds to a threshold and moving air produces sound. The sound is then converted into electricity by using "piezoelectric" devices that are squeezed in response to pressure, including sound waves, and change that pressure into electrical current"
http://www.tgdaily.com/content/view/32323/113/
The main downside is the intermediary. The heat is first made into sound... you know we all hate sound so that has to be shielded or canceled out. I can see some uses for this though. They claim it to be 20-25% efficent.
That GPU scorching along at 90*C might not be a bad thing anymore. Be kinda cool to have case fans run by your heatsinks. The hotter stuff gets the faster the fans spin etc...
