Processor affinity in Vista
MrEd
Ok, I think I've got my favorite game ( everquest ) at the edge of working in Vista, the thing that's kicking my #&$ at the moment I believe is the same old issue of running it on a dual core processor. In XP it was an easy fix, just needed to set affinity to one core and bingo everything worked, the problem that has me stumped is how do you set affinity for a process to single core in Vista, it doesn't allow me to make the change in task manager. I've googled the crap out of this for two days and came up with nothing, any of you know how ? I don't have an AMD dual core chip or I would try there fix, mine is an Intel X6800 so I've always done it manualy in XP. Thanks in advance.
