Process Type ?
sinplicity
ok what is the diff. here and which is faster? And does it even matter at this point?
Process Type: 90 nm
Process Type: 0.13 µm
AMD Athlon 64 4000+ by the way.
90 nm = 0.09 µm
130 nm = 0.13 µm
These numbers typically refer to the "feature size" of a manufacturing process. A "feature" could be a transistor, gate, etc. depending on the interpretation...but really, it doesn't matter. Just treat the numbers relatively.
Anyways, the basic concept of improving semiconductor manufacturing technology is to fit more features into less space, as technology improves. Another thing that happens with smaller manufacturing processes is that certain properties of semiconductors improve, while others cause problems. Generally, with a process shrink, gate voltage decreases, power consumption and dissipation decreases, and stable operating frequency increases. However, certain things become more troublesome as the process shrinks, like [parasitic gate capacitance and current leakage.
Generally speaking, though, the smallest process is best in terms of computational performance, power and thermal performance, and feature set.
