problems
marcobennetto
hi guys swapped out my mobo for a asus p5q-e motherboard
also added another hd4890 so now in xfire
reinstalled ati driver and chipset drivers
tried running 3dmark06 and getting 60 frames max ?
any ideas ?
also if anyone knows how to get my e8400 upto 4ghz on this board i would appreciate it
yeh done that m8
also i tried the memory and cache benchmark on everest and that is really low ?
this is what i get with everest.
whats with the low read , write and latency ?
when changing motherboard is a fresh install of windows needed ?
99% of the time: YES.
When you swap out your motherboard, you are making drastic changes to the system.
Everything from your Hard Drive Controller to your PCI interfaces. Sometimes, Windows won't even boot up after a Mobo swap.
Unless, you are swapping an identical board do to failure, RMA, etc. You should always do a fresh install of Windows.
Is your CPU overclocked??? 2 - 4890's will definitely be bottlenecked by a stock e8400.
60 Frames max in all tests?
What are your final scores?
3dMarks
SM2
SM3
CPU
Obviously vsync is on. ATI control panel might be broken. You might want to manually disable vsync through registry
