Problems with top mounted rad???
Teecee
I am getting a Lian Li G70 case with a 120.3 rad mounted inside on top of the case. I will also have a fill port at the top of the case. I do plan to use a resorvoir. Will I have problems with keeping air out of my loop and keeping my rad full of liquid due to the rad being mounted on the top of the case?
I got to thinking that since my rad will be towards the top of my loop, my res. will fill up leaving my rad with less liquid.
Any thoughts?
No.
Once your loop is filled with fluid (which you do by rotating your case and flipping it around to get the air out), it will continue to draw fluid (as needed) from the reservoir.
However, if you are gonig to put a fillport on your PC, why not just do a T-line instead of a reservoir? It will cut down on space, act as your reservoir, cost less, AND be the highest point in your loop.
