Problems with SLi with Evga 780i
preyed
Ever since I've had this Mobo and these cards, I've always had a hell of a time getting SLi to work. Everytime I clean out my case, it takes me hours to get SLi going again. The problem is that the bottom card never seats right, the only way I can get it to seat properly is by laying the case on it's side and booting up. After I get it to see SLi, I have to find a spot to screw/lock the card down but that takes ages too, due to the screws pull the card and it become unrecogized again. Is this a common problem? I've always swaped cards and it's always the same, it's that bottom PCI-E slot. Should I RMA the board now?
EVGA 780i
EVGA 8800GTXs
Things like that are usually the cards bracket that goes into the case, or the case itself. Rarely will it be the actual motherboard.
Try bending the pci bracket (not the part that you screw into the case) so that's it's completely straight. Once that's done, try seating the card again. That may fix the issue. If it's not the case or the bracket at all, and it is the PCI-E slot itself (again, this is REALLY rare)...
I'd talk to EVGA and see what they say.
thanks for the idea, bending it fixed it. Card seats fine now. Thanks alot
