Hello.
My hd' setup consists of
2x500Gb Raid0 Seagate ST3500320AS
1x1Tb Seagate ST31000340AS
1x500Gb Western Digital WD5000AAKS
Now everything worked nicely until one point when my OS started to "stutter", as in, the mouse cursor froze for a few seconds and I was unable to do anything, and releasing itself for a second and then froze again. I've scanned the drives with Spinrite level 1 scan and it didn't find any problems. Now I've downloaded Seatools and ran generic tests, of which all of them passed, though, I was unable to scan the raid array at all.
Then I though maybe I should try WD Data Lifeguard and proceeded to do so. It shows OK for SMART status for all drives though when I try to run a diag on any Seagat edrive it shows this.
Now, my OS is on the raid array and boots up and works just fine despite that error. The other 500Gb Seagate stutters when I try to read or write data to it, preventing me from using the OS up until I somehow manage to break the operation or unplug the drive. The other 1Tb Seagate drive allows me to read or write without problem.
I'm confused now. I took both 500Gb and 1Tb Seagate drives and put them into my other computer and ran the same test using WD software and it returned no errors.
Could my mobo be possibly damaged somehow? I'll confess I did some hot-plugging with my drives.
Maybe the BIOS is slightly corrupted.
Any thoughts?
EDIT: The mobo is Asus Maxmus Formula.
Any thoughts?
