PolygonGTC
- Jan 6, 2006
I have a Media Sonic Pro Box. It's a 4 disk enclosure I intended to use for backup to three drives. It has no options for RAID or JBOD. It's just supposed to show how ever many drives you put in there.
Sadly, mine is only showing one. The activity lights just sit and flash on the other two. If you pull all the drives and try each one individually they all work. This leads me to believe it's an issue with port multiplication. I was under the impression that my Asus P8P67 LE supported that via the eSATA port on the back.
Is there a certain driver I need to install or a certain setting in the BIOS I need to change?
