problems with new motherboard
i'm not sure of the exact wording in the bios but theres an option for usb keyboard and mouse during boot.
It probably does but how exactly is one supposed to get into the BIOS to set it if its not set in the first place? Make sure everything is plugged in correctly. Power Switch, Reset Switch, etc..
ok i dont have a bios speaker and the video card isnt working, im not sure if that is due to the mobo or not, it will sit there and run as long as i want it to but i cant see anything because the video wont work and i cant tell if there are bios errors because i cant hear anything (no speaker) and i cant find one on newegg, everything is plugged in and how am i suppose to enable usb devices in the bios if i cant use a usb keyboard to select the option?
