Today I received my brand new 9800 pro (OEM) from Mwave.com. Before I installed it I did a quick inspection on the build quality of the card, and found a glaring problem: The heatsink seemed a little loose and insecure; it would even move a bit when I wiggled it around. Thinking it was supposed to be that way, I carefully placed the card into my system. (Note: past 9700 drivers have been uninstalled prior to this installation)
I installed the drivers that came with the CD. After the computer rebooted and WinXP finished loading up for maybe 5 seconds, the whole screen became distorted with interference. Flickering everywhere, proportion way off, almost as if the card went throught a bad overclock. I restarted my computer again, and the problem did not reoccur. (Note: the resolution was 1280x1024 on a Viewsonic VP171b LCD)
After installing the newest Catalyst drivers, I ran a 3dmark03 test. To my dismay, artifacting appeared in tests like Battle of Proxycon and Troll's Layer. I stopped the test immediately. Games like Need For Speed Underground and Star Wars Knights of the Old Republic yielded the same artifacts.
I'm thinking the loose heatsink is the culprit. Can anyone give some explanation on what's going on? And what can I do about it?
