problems with my LCD
Swatman1
i had a 26 inch westinghouse LCD, and recently it broke, so i purchased a 32 inch Samsung LN-S3241D. Now i used to use DVI for my input, but since the Samsung doesnt have DVI i use HDMI for my PC input (i use the DVI cable with an HDMI converter)
my westinghouse ran in 720p res. the samsung runs the same way, however when i turned on my PC today, everything is stretched off the screen. My start bar is below the TV so i dont see it, and my sides are stretched where i cant click most programs.. the setting is 720 p so i dont know what the problem is. i reinstalled drivers but it didnt help.
the TV looks fine while watching cable or playing my 360, but it wont work correctly with my PC, can someone help
I thought TV LCD Monitor native resolution is higher then 1280 x 720. Isn't it 1366 x 768? Maybe that's why you see it blurry, it's under it native resolution. Did you try another monitor to see if it driver issue or your Graphic Card?
