Problems with my Geforce4 Ti4800
Znarf
[edit 2] Well.. I just found out that the fan on my card has stopped. Is there any possible way to revive it?
most likely not......go find a cheap VGA fan at the egg.....not too hard to install, don't run the card without its fan, bad things will happen
yah..or just throw a 80mm fan on it or something..but i would recommend a vga fan too if u dont know how to get that 80mm on there..
