I just built my new system with a factory-overclocked XFX GeForce 7800GTX. However, in game graphics look extremely good for a while, but then after a little bit of play-time, they become glitchy. Not sure how to describe it, the textures jump around. I can still play fine with this issue, its just annoying as hell. I'm using World of Warcraft to test this, but its happening with other games as well. I downloaded newest drivers for all my hardware. Do you think its a video card issue, or something else? What do you suggest I do? Thanks!
Also, and I'm not sure if this is related, when I first installed my system I did it with another standard-pci video card that I had. After installing windows, I put in my 7800GTX. Now, when I boot up my computer, windows won't start up unless I keep in the previous video card, even though I disabled it in the device manager. Unless I set the bios main VGA card to be a second video card (not the 7800), windows wont boot. So basically the only way I can use the 7800GTX is by having another video card in the system. Weird, huh?
Specs:
MSI K8N Neo4 Platinum SLI
XFX PVT70FUNDE Geforce 7800GTX
Antec NeoPower ATX 480W Power Supply
AMD Athlon 64 3500+ Venice 1GHz FSB Socket 939
OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual
Channel Platinum System Memory Model OCZ4002048ELDCPE-K
Maxtor DiamondMax 10 6L250S0 250GB 7200 RPM Serial ATA150 Hard Drive
COOLER MASTER Centurion 530 RC-530-SSN1 Black Aluminum Bezel, SECC
Chassis ATX Mid Tower Computer Case
Specs:
