Problems with MX510
UnlimitedMP
The darn thing doesn't work. It was working earlier today and then I shut down the computer normally and now when I turned the computer back on, it doesn't work.
The red light is on. I've tried diff USB ports. Re-installed drivers. Restarted. No harm/damage/drops came to the mouse.
In mouse properties, it just shows a generic logitech mouse. Does that mean it is not detecting it?
Ideas? :(
It seems to work ok in the other computer. It just won't detect on this one. Unpluggin repluggin many times doesn't seem to do anything.
Have you tried PS/2 Port?
(with the adapter that came with the mouse)
My mouse is working perfectly, but I am using that because it takes less cpu-cycles - even if you put the speed of PS/2 port to 200Hz
if it is under warranty A quick call to logitec will have a new one at your door in under a week.
and as a bonus you get to keep the old one..
cheers for logitec warranty service
hmm if you have reinstalled drivers I don't know what it could be.. do other mice work with that computer?
Well he said it works on another computer. So if logitech sends him a new one that might not work either.
Fixed. It seems it or my computer was finicky?
Like I mentioned before, yesterday, I replugged-unplugged many times before, inbetween, and after restarting a few times (repeated that process before and after reinstalling drivers). I told myself screw it and I'll fix it tomorrow.
I boot up this morning and it works and is detected and works normally. I had to redo my sensitivity settings. I'm glad, but confused.
