problems with HDTV lcd when using it with an HD 4850. your input please?
InCogneato
just got a 4850 and its pretty amazing. it seems a bit glitchy when using 2 monitors though. in the display config it gets my primary monitor (17" lcd) and my secondar monitor (40" hdtv lcd) mixed up quite a bit.
one problem seems permanent though, the gpu is not filling the entire hdtv. ive tried many things like reinstalling drivers, using ati catalyst, messing with the different primary/secondary options, resolutions, and nothing works. the hdtv is set to 1:1 so it should be filled up with 1920x1080, but it stays slightly short of it even hough the slider is indeed in the 1920x1080 position. i can switch my tv's mode to 16:9 and it will fill up a bit more but still not completely...
ive been using my monitors like this for over a year without problems in my previous nvidia card, and when i got this gpu yesterday it worked fine too until this morning when this new problem arrived for no reason. other glitchy stuff happens too like mixing monitor specs in the display config window, a bunch of rainbow grain everywhere, flickering in the monitors when changing simple options in the display config window, and more. today though this problem where the whole hdtv wont fill up with a picture hasnt gone away.
i am stumped. any ideas? how quick should new drivers come out (if its even a driver problem)? should i return it? what do you think the problem is? has anyone used a similar setup with the new ATi cards out there? thanks
Had the same issue. The problem lies with underscan being enabled by default. Go to Catalyst Control Center -> DTV -> Scaling options -> slide bar to the right for 0% Overscan and the problem should be fixed.
The other problems you've described sound vaguely familiar, as well. On my primary monitor (Samsung 305T), if I watch a video using anything other than VLC (which only utilizes the CPU for rendering I believe) I get artifact-like rainbow crap near the edges of the video. If I set color quality to 16 bit the problem's gone, but I don't want to do that. Alt-tabbing between windows and games is also really slow and flickery. Definitely not 100% satisfied with this card.
you are THE MAN!!!! this worked. thank you!
btw i only saw that rainbow grain once, and i re-plugged in my DVI cables and havnt seen it since then
ati was making a bad first impression on me with this whole thing but now that the scaling thing is fixed i am ok, things are still a little buggy and the damn card hits 70 degrees constantly, but ill be patient for drivers.
thanks again!
