Problems with Hauppauge WinTV PVR-250
dotdkay
Hey
I got a problem with my new Hauppauge WinTV PVR-250. I bought it a few weeks ago, and installed it, and searched for channels through the antenna. And it found all the channels that I can recive, and the quality was awesome, there was no noise on the images.
But yesterday I had to reinstall Windows XP, and I installed the drivers and so on, but now when I finished the search for the channels thorugh the Antenna, and with the same options as last time. Many of the channels have so much noise on the image and sound that it´s impossible to see anything.
I have checked that there is no problem with the antenna cable(I pulled it out, and put it back in again) with the same result.
Also I have a TV next to me, that runs on the same antenna, and uses the same antenna box, and there is no problems with noise or anything on the screen.
I hope that someone got a suggestion for what I can do?
Couple of things you can try:
- try using another program to watch TV to see if you can reproduce the problem. If you are using WinTV, you can download and install the free trials of BeyondTV and SageTV to see if you get the same problem.
- you can try physically reseating the card, or better yet, move he card to another PCI slot - farthest away from the AGP port if possible - and let windows redetect and reinstall it. Something my have gone awry with the autodetect during your new WIndows install.
hth,
Make sure you run the latest drivers and set it up as required.
Try changing the primary settings.
Go to the support sight and e em about it, They were great for me got back the next day.
rescan channels
Did you update windows and have DX9?
Try here:
Hauppauge PVR board
