Problems with GTO
I downloaded RivaTuner enabled masked units and did the custom thing by putting checkmarks next to the disabled ones. I applied them restarted and it still says 12x1 5vp. Drivers are 61.78.
I have the same problem. There are people here who have been successful. What drivers, OS, other settings, etc. did you use?
I think i read somewhere that you need to use the newer forceware drivers, maybe the beta ones. Someone else that has done it should be able to help more.
Yeah but no one here wants to help :(
botreaper10 said:
Here, use the beta forceware 66.81 and see if that fixes the problem!
tried it :)
Ive been looking on guru3d.com and there are people working on the problem, I guess I will just have to wait and see if they find anything.
