Problems with Gigabyte Duo Rev. 1.1
Lord Nassirbannipal
After installing in my new system, I couldn't get WinXP to install. It would get to the point just before it begins copying system files, and then give a message saying that "windows had to be shut down due to an error."
Soon thereafter, my PSU died, and took out my two rear case fans as well as the LED on my side fan.
There are 3 IDE channels on this board, and during POST, it doesn't recognize anything on channels 2 and 3, but shortly after the post screen, it seems to think I'm going for a RAID setup, as it says "Raid not possible with current drive"(or something to that effect), and then it shows the drives that I have connected to the other channels.
The BIOS doesn't recognize anything on channels 2 and 3, but when I use my MAXTOR or WD software to setup any of my 4 drives, it recognizes that all of them are there, even on channels 2 and 3, and the device manager in Windows 98 does as well, but WinXP only recognizes drives on channel 1.
Is it possible that the PSU dying has something to do with this, or is there something in the BIOS that I can adjust, or are channels 2 and 3 just borked and should I RMA the board???
Tried clearing CMOS, didn't work, so I'll try flashing the BIOS next.
If that doesn't work, I'm RMA'ing the board.
I had that motherboard for a very short time. The same problem happened to me trying to use my two Seagate SATA drives. Weird as it seemed, after a few reboots, it recognized the drive and I installed an OS. Then on the reboot after the initial install, it didn't recognize it anymore. I had to play around with several settings including boot priority and IDE settings, but don't remember what I did exactly. I returned the board after a few days once my new board arrived. If you look at neweggs listing, you will see my review of it and several other complaints about the motherboard. Basically it was the worst experience I ever had with a mobo.
I'll try those things.
Basically, I only got this board because it accomodates so many hard drives, but if the problems continue, I guess I'll go for another.
