bigbadgreen
- Oct 2, 2003
Here's the deal. I recently upgraded my computer and decided to give my old system to my brother in law, he really needed an update. I know there are always issues when changing hardware and doing a clean install, it's murphy's law, but this is beyond me.
This system ran rock solid for me for close to two years at it's current config. I didn't change a thing.
The hardware is as follows, the mobo is an asrock dual sata 939 with a 3500+ oc'd to 2.5ghz. 2gb of ocz gold, an antec true watt 430, and a 6800gt agp. He added in an old soundblaster card, I kept my X-fi. He has two ide hard drives and two optical drives, I kept mine but also ran two hard drives of similar size and brand, and two similar optical drives. We both ran floppies as well. WE also have the same number of fans, but some of his are 80mm and all of mine are 120, and they are all the same brand. The issue is that it does pretty much everything fine except play games. It will freeze about 3 minutes into BF2, and won't get past the intro movie to medieval II total war.
Here is what I've done to troubleshoot. It's not heat. I added three 120mm and an 80mm fan to his already two 80mm fans. I was cutting and drilling. The cpu idles at 35C and loads at 49C tested with super pi. He got my zalman 7700-cu and was running it on the highest setting. The 6800GT is at stock speeds and idles at 51C, not sure what it loads at, but he also got my zalman vf900-cu and is running at the highest speed. The airflow is quite good in this thing.
I had him reinstall the mobo's chipset drivers in the order I did, taken from an order posted on overclockers.com. He's using the same version of uli unified drivers that I did. He installed everything in the correct order. He has the last driver they made for the 6800GT, 94.something. He reinstalled this as well. I am having him get an older driver that seemed to work well for many people 71.81. He hasn't reported back to me yet about that, it's only been one day. The card is also on it's own power cable, no other drives or fans on it.
I don't think it could be the power supply. Unless it's time has come. I have used that one for close to 5 years now, but the rails looked good, with negligable fluctuation, and good output. I do have a newer (less than one year) true watt 480 I could throw in there but he's 3 hours away. I'm trying to exhaust other options first.
Windows did install his soundcard on it's own. Everything was named correctly in device manager, it looked to be a good install. However I am having him reinstall it just to make sure.
Before He started it up after transporting it back to his place I had him check to make sure all of the cards and heatsinks were secure, as well as the ram and all the power connections.
Other than this I don't know what it could be. This setup was solid for me and now suddenly it has problems. the install is a week and a half old. Any other suggestions would be great.
