Problems with EVO?
You can easily install those Sprint apps again, and there's an HTC keyboard you can sideload as well. Remember, you can do a LOT more than you thought with Android.
nOOb question.
Once rooted and let's say you backed up original ROM etc. possible? How easy or hard is it to go fully back to factory fresh on EVO? Will the 2.2froyo stick or will it need reinstall? .. I swear I've seen a post mention that the firmware updates stay somehow when you restore.
Sorry off topic
I swear that would make a good commercial "You can do a LOT more than you thought... with Android!"
I'll have to see if I can find them then, they weren't in marketplace (which is odd since so many OTHER sprint apps were...)
@ MrkXCeL:
If you made a backup of the original ROM or have it downloaded from elsewhere (I think there's a copy over at XDA Developers) you can simply re-flash it onto the device same as you flashed your current rom.
EDIT:
Just an update to say I found all the Apps I wanted including the HTC Keyboard and now I'm Thrilled the the phone/Cyanogen ^_____^
