I have just installed this mobo with a A64 3200+ (939 winchester). It is a great board but seems very finicky when it comes to memory. I know that the Athlon 64s are more touchy on memory. I have 2x512mb sticks of Corsair XMS 3200C2 (CMX512-3200) memory and I can not run them dual channel, they are only running at 333, and it only sees a total of 512mb of ram. These were not a matched pair, they were bought months apart. One is v2.2 and the other is v3.1.
While in CPU-Z I get odd readings on this memory. On the SPD tab it lists the dimms as follows:
v2.2 166 2/3/3/7 - 200 2.5/3/3/8
v3.1 200 3/3/3/8
According to Corsair I should be able to get 2.5, 3, 3, 6 with these sticks on an AMD CPU. Shouldn't I get these timings at 3200 (200)? It is weird that the one stick is being rated at 3 cas.
I have tried changing memory settings with no luck. I have tried all the dimm slot combinations. I have confirmed that all the dimm slots work and that both sticks work. Even though windows sees only 512mb I can see both sticks of the memory while in CPU-Z. If I have one stick in it runs at 200 and if 2 in at 167. I'm running the latest bios for the motherboard. These sticks ran dual channel on an ASUS A7N8X V2 Deluxe mobo.
Help! Any ideas?
Thanks!
v3.1 200 3/3/3/8
Help! Any ideas?
Thanks!
