Problems with D-link WBR-2310 Router
Basically i can't get to the internet through the router.
I've tried setting this thing up at 2 different houses/networks, and i can connect to the network locally, but i cant get to the internet, Am i missing something about this router?
Thanks in advance!
I am not too familiar with this router, but I would try clioning the mac address of your PC. Most likely your ISP has it set to one MAC address.
If you can connect to the internet through your modem, this is probably this best route to try,
If this does not fix it, please post a little more about the network.
ISP? Modem used? What machine is connecting to the router, any\ changes made to the router?
Hope this helps.
Hope this helps.
Ahh you know what thats a good suggestions about the MAC address. Ill try that here in just a lil bit, as im in the middle of uploading a large file, damn slow UP times.
I'll post up what happens after the change. thanks
