Problems with Creative
Status
Not open for further replies.
i have a soundblaster audigy ES 5.1, model # sb0160. which consequently isnt even listed on the creative driver download site. but anyway, initially the software that was installed with the card (like the creative audio hq and surround mixer) dissappeared somehow from my computer. so i tried to uninstall and then reinstall the drivers. but when i tried to uninstall this message popped up:
"error number: 0x80040201
description: an event was unable to invoke any of the subscribers
setup will now terminate"
and this message shows up no matter how i try to uninstall (through the cd or add/remove programs) plus i can't run the repair option either on the first installshield screen. also the sound blaster audigy listing on my add/remove programs list will not remove. i still have the installation cd. any suggestions to try and fix this problem?
Mod Edit - Tsk, tsk.....per the rules:
(13) POST to the forum that is most appropriate for the topic being presented.
Spamming the same thread across multiple forums is very much frowned on. Here's a link to your still active thread in Computer audio.
Thanks - B.B.S.
Status
