turtletrax
- Dec 31, 2005
I have my X2 running close to redline with Vcore and dont need that horsepower for much but gaming. I want to run two settings, one for usual stuff such as surfing and everyday use, then have the high power for gaming and encoding.
Problem comes when I set a bank for each bios setting and set the hotkey, the hotkey wont work. Always boots to the bios settings that were last loaded. I have tried multiple hotkeys and wonder if it is my Dinovo BT keyboard...
I have USB motherboard support enabled and have no problems otherwise with using the keyboard prior to windows booting (ie getting into the bios) so I doubt it. Any other suggestions?
Thanks.
Thanks.
