Problems with Biostar Geforce6100 M7 Build
jdogg707
I put together a new system for a client using the following components:
AMD Athlon 64 2800+
Biostar Geforce6100 M7 Motherboard
Corsair 1GB ValueRAM (2 x 512MB)
Hitachi 80GB SATA II Hard Drive
NEC 3540A DVD+/-RW
Onboard Video
Onboard Audio
CoolerMaster 350W PSU
Here is the problem. I get everything connected, hooked up and ready to go. The PSU is only 20 Pin and the motherboard has a 24 Pin connector, but I have heard that this should be fine if I am not using a PCI Express video card, so I just hooked it up to the first 20 pins. The system powers on, the CPU fan and system fan power up, the hard drive light comes on, but I get no video, my Hard drive may or may not be spinning up, and my DVD drive will not open.
Could it be the lack of a 24 pin PSU? What could be the problem? Any ideas?
Thanks.
BTW, I have tried two different PSU's that were both 20 Pin and they have the same issue.
Try only 1 stick of RAM and move it around to different slots.
Make sure the CMOS jumper isn't on the wrong pins :). I've had boards where they ship in the clear position and had the same problem right off the bat ;).
Thanks for the reply! I tried both things and I am still getting the same problem. Could it be a bad motherboard?
I guess you could try a new PSU, but I don't think the 20-pin PSU would be a problem (never was for me even on SLI boards). Might be different with integrated video though.
Not sure if this is applicable to your situation, but I just built a system last night using the Biostar T Force 4U, and it wouldn't work unless the extra little 4 hole plug was plugged into the m/b...not the part that turns the 20 pin into a 24 pin, but the other one that goes on the mb over towards the CPU. If you have and older psu, you may not even have this plug.
I've built other systems with boards that had this plug, but never plugged anything into it, and everything worked. On the 4U, however, it was DOA power wise 'til I went ahead and plugged that in. BTW, everything worked w/o the other one plugged in (the one that does change your 20 pin to a 24 pin).
Sorry if my descriptions aren't very articulate...it's pre caffeine time here lol.
I have a biostar 6100-M7 and I never got it to work with any of the 20 pin power supplies I had (three different brands).
Fortunately I had just ordered a 24 pin that had a break-away 4pin.
It works with the full 24 but not the 20.
By the way, I also have to push the power button three times in some cases to get the motherboard to power on completely. This is definitely a bios problem since when I flash the TFORCE 6100-M7 bios over it, the problem goes away completely.
It also will not do a proper "restart" from windows, it does a shutdown instead. Same thing with ctrl-alt-delete from DOS. Again, problem goes away with Tforce bios.
I've told biostar USA and biostar taiwain about the problem almost a month ago at this point, but obviously they are not in any rush to fix it.
The over-volting options on the Tforce bios will not work on the regular Geforce 6100 but if you are not trying to overclock right now, you can try flashing it too.
Latest Gforce 6100-M7 bios:
http://www.biostar.com.tw/support/bios/bios.php3?model=GeForce 6100-M7
Latest Tforce 6100-M7 bios (plain 6100 means M7)
http://www.biostar.com.tw/t-series/download/bios_details.php?id=1
REMEMBER YOU MAY NEED TO CLEAR THE CMOS with the jumper after you flash bios from Gforce to Tforce, etc.
Unrelated to your boot issue but you are also going to want to upgrade from the default nvidia drivers that come on the CD since you need SATA support. CD = 8.12 newest=8.22:
http://downloads.guru3d.com/download.php?det=1239
Last but not least the new CPU-Z 1.31 will read the SPD info on the 6100 which no other utilities does yet, handy to know.
Thanks for the replies! I DO have the 4 Pin 12v Connector hooked up by the CPU.
Vibe:
I will try the Antec TrueControl II 550W unit in my gaming rig in the system to see if it makes a difference. If it powers on, I know it is a PSU issue and I will order a new PSU, but if not, I guess it is a motherboard issue.
Would you recommend flashing the BIOS to the Tforce BIOS? If so I will have to do it once I get it up and running. Will I have any problem using winflash to do it?
Well tried the 24 Pin PSU from my rig and it worked like a charm. I will be ordering a new PSU ASAP! Thanks!
First time I've seen that the 24 pin PSU was required. I guess the integrated graphics makes a difference. Good to know for the future ;).
Just a guess on my part but I bet that's also a bios issue.
It didn't occur to me to try it but with the Tforce bios I wonder if 20pin will work.
I haven't been impressed with Biostar's bios work.
They don't even have SMBUS/SMBIOS support.
You can flash the Tforce bios in using either the flasher built into the BIOS or I use awdflash. I am assuing winflash would work just as well. There is supposedly a protected bios boot block recovery mode, so as long as you make a bootable floppy with the Geforce bios, in theory you can recover from even the worst bios flash disaster. Never had a need to try it. I did have to reset the cmos more times that I liked though.
So far my board is very stable as long as I don't have to restart windows. The shutdown is very annoying and I wonder how it stresses the rest of my hardware to have to restart it three time to boot. Biostar has acknoledged the problem but no promise for a fix.
By the way there is a new bios out for this board that Biostar has not published yet on any site, they just sent it to me, #18 released 10/14
You can email them for it from the www.biostar-usa.com site
