Problems with ATI 5570
computer
A few months ago my monitor was much dimmer than it should be even though the brightness was set to maximum. I was finally able to get it fixed by updating to the latest ATI/AMD drivers. Yesterday my monitor became dim again so of course I upgraded my drivers. Thankfully this has fixed this dim monitor issue again, but now whenever I play Counter-Strike: Source quite a bit of the graphics in the game are pink. Before this upgrade I only occasionally had a few pink graphics which usually seemed to occur whenever I minimized the game and went back into it. Can anyone think of what the problem might be?
This is my card:
SAPPHIRE 100293L Radeon HD 5570 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Low Profile Ready Video Card
http://www.newegg.com/Product/Produ...74&cm_re=sapphire_5570-_-14-102-874-_-Product
The pink hue is because in the color setting of the CCC the color "temperature" changed.
It is a known bug,
In Catalyst advanced mode >>> Desktops & Displays >>> Right click on the monitor icon at the bottom and choose Configure... >>> Color Tab at the bottom move the slider to 6500k iirc.
It is a known bug,
You have to put everything at default. If you move the saturation/hue/brightness/contrast setting on that page, the pink tint will still come back. At least for all of the 10.10 releases.
