Problems with Asus nForce2 board
N
NecessaryEvil
Guest
Asus A7N8X will not post.
traded CPUs, RAM, videocards, etc....it still won't work. the mobo was taken out of the chassis and tested bare...still nothing.
Any thoughts on what it might be? It was working earlier tonight...and after resetting it, it no longer worked.
have you tried resetting the CMOS? that's all i can think of right off the top of my head.
a shit load of times.
even pulled the CMOS battery out and reseated everything.
used a different PSU...same deal.
CPU, RAM, videocard, and everything else are working perfectly on a new board.
odds are this is death, but there's no rational reason for it to have occurred, as it was working prior to rebooting.
just got it home. Let it spend all day without the BIOS Battery in, and have it booting.
It says there's a CPU failure...although the system boots just fine. Posts, and booted into the Ultimate BootCD's tests.
Currently, it's conducting the Mersienne Primes benchmark/torture test...and I'm letting it run indefinitely.
Question is...
If the system posts...passes the stress tests, and generally works other than the Asus lady's saying CPU failure...should I use this board or toss it?
Also, when I first booted it, it said mobo temperature was around 176F...and CPU temps were around 82F.
next time I booted it, it wasi mobo temps were around 60F, and CPU temps around 92.F
Now....the best this mobo could ever be considered is "flaky"....but with it offering so much, I'm somewhat hesitant to pitch it out right away...especially with regards to its competition (a Celeron 800 w/ USB 1.1, vs. an Athlon 1ghz w/ USB 2.0)
Oh, mobo is an A7N8X. haven't been able to find out if it's a deluxe or what, but since it includes 2 NICs....I'm assuming so.
