Problems with ASUS mobo.
DMystikaLD
My friend here at college's motherboard has some problems. Apparently while taking off the heatsink he ripped part of the ziff socket off (very small chunk) but it's enough to make it so he cannot mount heatsinks... when he did it he barely even pulled and it just "cracked."
I didn't see it happen, but is there a way we can mount the heatsink some other way? It's an Athlon 3000+ on an nForce 2 based chipset from the looks.
It's a fairly new motherboard and he probably could get away with RMA'ing it. He's pretty damn good with hardware... it's really odd that it happened, but still his fault.
Any suggestions? I thought about using the little 4 pads and superglueing a light weight heatsink to it but even still with that there's no way in hell it would hold.
Is it safe to actually place superglue or epoxy (sp?) on the processor to hold the heatsink to it... it's probably pretty stupid and the first answer that comes to my mind is no way in hell, but even so, it's better than buying a new motherboard (well, unless he ruins a processor with it). Blah.
I need suggestions guys. Thanks.
Does the board have the 4 holes around the socket for attaching water blocks or large HSF? If so he could buy one of the SLK U series bolt on HSFs.
Regards, Szandor
