problems with asus k8v board
Aleks
Long story short I'm building a computer for a buddy and can't get this board to work.
First of all, right after post I see a message that says 'BIOS not installed...' but I can get into bios fine and everything shows up and I can navigate through it just fine.
When I try to boot a windows xp disk for install (i tried like 4 different discs) It makes it seem like its working (hit any key to boot from cd rom, inspecting hardware) but it never makes it passed the inspecting hardware config black screen. The screen stays black and just stays there.
I tried reflashing the bios, but I don't have a floppy disc so I made a bootable cdrom and put the necessary files on there but it won't budge and says it cant find the file (maybe I need to do it through floppy).
Its an Asus K8V SE Dulexe, Kingston HyperX 1GB and athlon 64 3200+ with a 250gb maxtor PATA harddrive and lite on dvd burner.
I'm running one of these boards. The 'BIOS not installed' line has to do with the FastTrack software for SATA RAID arrays. I see it every time I boot and it doesn't seem to affect anything, so you can rule that out, but no other ideas with the info you've given.
