Problems with a S3 Graphics ProSavageDDR
TITAN24
I know its a crappy video card but its what im working with in my laptop. Im trying to install the program that i downloaded off the website so i can get the new drivers and they wont install it just tells me to check the log. When i do i get this msg
=========== S3SETUP LOG FILE - Started at 05:03:20 on 2-4-2005 ===========
S3Setup v1.00.17-JV (1.01.13) on Win XP
bAllowReboot: TRUE
bSilentReboot: TRUE
bPromptReboot: TRUE
bPromptSilentReboot: FALSE
VendorID to find:5333
INF File Located at: C:\S3Graphics\PSDDR_wxp_w2k_139428\ps5333.inf
Found - ven:5333 dev:8D04 ss_dev:8375 ss_ven:1071 rev:00 bus:01 devnum:00 func:00 (inVGA=0)
Enumerating Display class devices...
Display #0 has DevInst=00001848
Instance=PCI\VEN_5333&DEV_8D04&SUBSYS_83751071&REV_00\4&26E5833C&0&0008.
Found matching display.
No more displays.
Found InstID=PCI\VEN_5333&DEV_8D04&SUBSYS_83751071&REV_00\4&26E5833C&0&0008.
Found Mfg line: "S3.Mfg".
Description="S3 Graphics ProSavageDDR = S3Psddr, PCI\VEN_5333&DEV_8D04".
'DriverVer' is 6.14.10.0028, 'DriverDate' is 06/03/2004.
Calling UpdateDriver... with PCI\VEN_5333&DEV_8D04&SUBSYS_83751071&REV_00
and INF path at C:\S3Graphics\PSDDR_wxp_w2k_139428\ps5333.inf
Started Timer window in background.
Doing copy logging.
Finished with copy logging.
UpdateDriver forced install (PCI\VEN_5333&DEV_8D04&SUBSYS_83751071&REV_00) failed->5.
UpdateDriver failed, returned 5. Cannot install.
DestroyTimerWindow OK, but no timer dialog action occurred.
-> Setup was unable to complete the installation. Check the progress log in your Windows directory for more details.
Does anyone know what this means or where i can find out what the problem is and how to fix it. I would really appreciate it.
