Problems with a Matrox DualHead2Go and monitors
scarredtaka
Hi,
I purchased a matrox dualhead2go digital edition, which I have hooked up to my Macbook pro, and 2 22" widescreens. With both screens I should have a combined resolution of 3300 by 1050. However, when I activate the resolution, everything is squished together, and the left 1/3 of the left hand monitor is blank, and the edge of the resolution is sitting there about 1/3 to the way of the monitor.
I have a couple ideas as what may be causing this. One is that the computer won't let me select 3300 x 1050 as a resolution, I am using a program that lets you make custom screen resolutions to create the resolution, and there may be issues in there.
Another is that even though the Dualhead2go unit is digital and using DVI, I bought DVI to VGA adapters so I wouldn't have to buy DVI Cables. Therefore, I think the (dualhead) system thinks its running using Analog, and may not be allowing me to access the higher resolutions correctly.
(The company makes a digital and analog version, and the analog version has a lower maximum resolution than the digital one.) The analog version has a max resolution of 2560x1024. I am able to run the screens together at a resolution of 2560x1024, but the image is slightly distorted. It's usable for web surfing and typing, but graphics work and gaming are out. Again, see above for what happens when I try to go to a higher resolution. I think that if I switched to DVI Cables it might work, seeing that 2560x1024 is the upper limit of the analog version. (I'm thinking this is the culprit, can anyone help on this point especially?):confused:
Finally, the website says that the resolution I want (3300x1050) is only available under Windows. I am using a program to custom create the resolution, but it may still be an issue.
I've spent over $1000 trying to get this dual screen setup working, (tried another card that didn't work, and a smaller screen) and want to be able to use this setup.
My macbook pro is the older generation high end 15" with the 256MB ATI Radion X1600.
Any help or ideas anyone can give me is much appreciated.
Thanks,
-ST-
