Problems with a K8V-X
So I bought a K8V-X board with an AMD 64 3000+. The board powers up all right, and my power supply (450W) has no problem powering up everything else. I have all the right things plugged in. BUT, when I try to connect my IDE devices to the motherboard, they won't power up. As in, if the IDE ribbon cables aren't connected, then the IDE devices will power up, but if the IDE ribbon cables ARE connected, then the IDE devices will NOT power up! EXCEPT when I use a certain ribbon cable that I have. The devices WILL power up then. There seems to be no difference AT ALL between the ribbon cable that works and the ones that don't. Anyone have any idea?
Also, the board doesn't seem to be recognizing my video card (ATi Radeon 9700 Pro). The card powers up right, and I have the supplemental power cord plugged into the card. But I get no video display at all.
Someone I talked to before this post said it might be my memory... but I have a stick of Kingston DDR400 in there (256MB), and there's no reason why that shouldn't work.
I'm on the verge of insanity now. Is the board just defective? Am I missing something? Help!
