Problems with a external dvdrw
Status
Not open for further replies.
qwestor
I recently purchased a vantec nexstar enclosure to put my liteon 160p6s. When I try to use nero to burn a dvd it will spin up and then say drive not available but the error I get is could not perform end of disc at once, here is the log nero created.
1c82-004k-19e5-maax-4000-7xm1-4a26
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM
NT-SPTI used
Nero Version: 7.2.3.2
Internal Version: 7, 2, 3, 2
(Nero Express)
Recorder: <LITE-ON DVDRW SHW-160P6S>Version: PS08 - HA 2 TA 4 - 7.2.3.2
Adapter driver: <USB 2.0> HA 2
Drive buffer : 2048kB
Bus Type : set to ATAPI (3) -> ATAPI, detected: ?
CD-ROM: <JD3371W HXL555M >Version: 1.0 - HA 1 TA 1 - 7.2.3.2
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : ST980829A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : MATSHITA DVD-RAM UJ-840S atapi Port 1 ID 0 DMA: On
CdRomPeripheral : JD3371W HXL555M 1.0 dtscsi Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
MATSHITA DVD-RAM UJ-840S E: CDRom0
JD3371W HXL555M G: CDRom1
LITE-ON DVDRW SHW-160P6S H: CDRom12
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 894MB (915952kB)
Free physical memory: 206MB (211044kB)
Memory in use : 76 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
9.8.2006
ISO compilation
10:15:34 AM #1 Text 0 File Isodoc.cpp, Line 6427
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 2 (Max. of 31 chars)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
10:15:34 AM #2 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 262144KB of Memory
10:15:34 AM #3 Text 0 File Reader.cpp, Line 124
Reader running
10:15:34 AM #4 Text 0 File Writer.cpp, Line 113
Writer H: LITE-ON DVDRW SHW-160P6S running
10:15:34 AM #5 ISO9660GEN -11 File Geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
10:15:35 AM #6 Text 0 File Burncd.cpp, Line 3400
Turn on Disc-At-Once, using DVD media
10:15:35 AM #7 Text 0 File DlgWaitCD.cpp, Line 289
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2269999 (504:26.49, 4433MB)
10:15:35 AM #8 Text 0 File DlgWaitCD.cpp, Line 301
Write in overburning mode: NO (enabled: CD DVD)
10:15:35 AM #9 Text 0 File DlgWaitCD.cpp, Line 2715
Recorder: LITE-ON DVDRW SHW-160P6S, Media type: DVD-R
Disc Manufacturer: RITEKF - 1
Disc Application Code: 64, Disc Physical Code: 193
10:15:35 AM #10 Text 0 File DlgWaitCD.cpp, Line 473
>>> Protocol of DlgWaitCD activities: <<<
10:15:35 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2270000 (2270000) = #2270000/504:26.50
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2270000 blocks [H: LITE-ON DVDRW SHW-160P6S]
10:15:35 AM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [H: LITE-ON DVDRW SHW-160P6S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4648960000, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2270000 | lead-out | 1 | 0x41 | 0x00
10:15:35 AM #13 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
10:15:35 AM #14 Text 0 File SCSIPassThrough.cpp, Line 84
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
10:15:35 AM #15 Phase 24 File dlgbrnst.cpp, Line 1730
Caching of files started
10:15:35 AM #16 Text 0 File Burncd.cpp, Line 4231
Cache writing successful.
10:15:35 AM #17 Phase 25 File dlgbrnst.cpp, Line 1730
Caching of files completed
10:15:35 AM #18 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 16x (22,160 KB/s)
10:15:35 AM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:15:35 AM #20 Text 0 File DVDR.cpp, Line 2869
Recording mode: Sequential Recording Mode for Multisession
10:15:35 AM #21 Text 0 File DVDR.cpp, Line 3025
Start write address at LBA 0
DVD high compatibility mode: No
10:15:35 AM #22 Text 0 File Cdrdrv.cpp, Line 8995
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
10:16:12 AM #23 SPTI -600 File SCSIPassThrough.cpp, Line 291
H: CdRom12: SCSIStatus(x00) WinError(121) NeroError(-600)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x05370000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
10:16:12 AM #24 CDR -600 File Writer.cpp, Line 302
Device not available
10:16:12 AM #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
10:16:12 AM #26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
10:16:12 AM #27 Text 0 File DVDR.cpp, Line 3265
EndDAO: Last written address was -1
10:16:29 AM #28 SPTI -600 File SCSIPassThrough.cpp, Line 291
H: CdRom12: SCSIStatus(x00) WinError(55) NeroError(-600)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Buffer x05132000: Len x20
10:16:29 AM #29 SPTI -600 File SCSIPassThrough.cpp, Line 291
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x5A 00 05 00 00 00 00 00 48 00
Buffer x035bb200: Len x48
10:16:29 AM #30 SPTI -600 File SCSIPassThrough.cpp, Line 291
Sense Code: 0x00
Sense Qual: 0x00
10:16:30 AM #31 CDR -600 File WriterStatus.cpp, Line 167
10:16:30 AM #32 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
10:16:30 AM #33 SPTI -600 File SCSIPassThrough.cpp, Line 291
Sense Code: 0x00
Sense Qual: 0x00
10:16:30 AM #34 SPTI -600 File SCSIPassThrough.cpp, Line 291
Sense Code: 0x00
Sense Qual: 0x00
10:16:31 AM #35 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 16x (22,160 KB/s)
10:16:31 AM #36 SPTI -600 File SCSIPassThrough.cpp, Line 291
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x1E 00 00 00 00 00 00 00 00 00 00 00
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 4/25/2005 2:03:00 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 8/4/2004 3:00:00 AM (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
The really odd thing is that it will burn any type of cd but will not burn a dvd no matter if it is just 4 meg or 4 gig. I have tried memorex,sony,ridata, and a verbatim dvd media in it. It is hooked up directly to my laptop, which is a compaq presario v2000 series: 1.8 ghz turion,1 gig ram & 80 gig hd) not thru a hub. Any help with this would be greatly appreciated. Also does the same thing with the included burning software SonicMy DVD Plus. Thx in advance.
Have you tried to update the firmware if there is any?
Firmware is up to date. The drive was working fine about 3 weeks ago when it was in my desktop but refuses to burn dvds now.
Status
