HighwayAssassins
- Mar 2, 2004
I used the flash guide on this site and used the supplied bios with the 1.4 volts and the GT clock speeds (350/1000) and i can OC to Ultra speeds and it works beautifully. I just wanted to have the clock speeds set in the bios so i never have to worry about overclocking when i format and things like that. I take the same file and edit it with "OmniExtremeEdit FX" and i change the clock speeds to what i need, then flash the card with that bios. When i reboot, it works just fine, no problems. The problem is when i run rthdribl the computer chunks hardcore and i cant move the mouse for about 30 seconds then it seems to render 1 frame and chunk again, during this chunking the mouse doesnt move or anything. The funny thing is when i take this same flash and enable OCing, and set it to Ultra speeds (400/1100), it works fine!
Anyone know how to fix this problem?
