Problems Uploading pictures
Status
Not open for further replies.
Every time i try to upload a picture into the forums, or an image hosting site like photobucket.com, it never uploads, always says "page cannot be displayed" (my internet connection is fine). Does anyone have any suggestions?. Thanks. :(
well you can't exactly "upload a picture into the forums" so I don't know what you mean by that.
In any case, go here:
http://images.dr3vil.com/.
and hit "Browse" and select the picture you want to post.
Then hit Upload.
Wait for it to upload, then on the next screen hit the "Copy" button. This copies the necessary code into your clipboard.
Then come here and start a new thread (or reply) and with your cursor in the message section, hit Ctrl-V (Paste) and that should do it for you.
no, i mean when i try to upload an image (just like in the link) in never uploads, it just eventually says "page cannot be displayed"
Well it has to be something on your end. Do you run any kind of software firewall or anything else that could be affecting your internet connection? Can you upload other types of files okay or does nothing work?
The forums dont hold any images. You have to host them on a server then use the IMG tags with the location of the pictures to put them into your post.
If this is what you are doing and seeing a page cannot be displayd error instead of the picture you want to post then either the location is wrong (remember it has to be from a source other than the forums or your computer, IE a URL needs to be used) or the tags werent used right.
EDIT: Nevermind I see that your trying to upload images to a webserver to use.
Status
