Problems starting up...Vid. card died?
Status
Not open for further replies.
CanonicalAbstract
Special Attention Whore
First off, the specs:
Pentium III 1266Mhz, 512MB RAM, 80GB HDD, GeForce3 video card, Sound Blaster Live! Sound Card, Asus TUSL-2 mobo, Antec 350W Power Supply.
Anyways, my computer has been in storage for just about a month now, and today, I finally got a chance to set it up in my new place and turn it on. Before I turned it on, I gave it a nice dusting with compressed air, and installed this PCI bus fan, just below my video card. Its designed to suck air out and exhaust it through the PCI slot. I have this proped up so it takes the hot air off my video card, kinda like an exhaust port for the video.
Anyways, I turned it on, first thing off was this high-pitched squeal coming from my speakers. I double-checked, and my sound was plugged into the right jack on the sound card. Next thing that happened, the video started going blank, then coming back on, going blank, coming back on, on random. I also noticed that the upper-right part of the monitor was displaying a red "haze" around whatever icons / text was there. Finally, the video died, did not come back on. I reset the computer, the display came back on. But then the computer froze at the Windows 2000 splash screen. Reset it again, did the same thing, except this time with the high-pitched squeal. I opened the case, and looked around. All my fans seemed to be working, but then I noticed the fan on the video card... spinning slowly, speeding up for a split second here and there, like something was restricting it.
I still have some other testing to do with the card, but here are my questions:
- Is the video card borked?? I think I remember smelling a slight hint of something burning for a minute, is it possible something got burned out??
- Is it possible for one card to burn out, and take another card with it?
- Could it be possible the fan I installed has something to do with everything messing up this way?
- Could it be possible that I am consuming too much power from the PSU??
Any and all help is appreciated thanks!! Please respond by this evening, as I won't have much access to a computer after that.
It is possible that the fan you installed in the PCI slot was the straw that broke the camels back (as it were) for you PSU. You could have just exceeded your systems maximum power capability. Try yanking that card out and see if the problem goes away.
A slow fan on your vid card could be power related or it could be the fan is on it's last leg. After yanking that cooler card and trying again, if the fan is still slow you have a few choices.
1. Replace the GPU HS and HSF with aftermarket parts
2. Remove the fan from the vid card, flip over, peel back the sticker to expose the bearings and carefully put a tiny drop of oil (I use either 3-in-1 or a high quality Mineral Oil) in the port.
3. Buy a new vid card.
I do the second option (not to be confused with doing numer 2) quite often on my older compters to keep those suckers up and running with limited maintenance $$.
The way I see it is, with a 350W power supply, I should not have a problem with running 2 CD drives, 2 HDs, CPU fan, motherboard and 2 case fans on the PSU. However, you might be right.
When I get home today I'm gonna yank the fan out, and try it again. However, the fan on the video card does make little chirping noises from time to time, so it may be the fan is on its way out.
I really do not want to take apart the HSF and the fan, I'm afraid of causing more problems than I can deal with on the PC right now. If it comes down to that, I'll just buy a new video card to tie me over.
Thanks so far!! I'll keep updates!
Well, here's the stats:
Good news is, I was able to get my computer on the internet. This is an important step, as I have to set up my friend's computer now, reformat, and get his internet going.
Bad news... my sound card is borked I think. I don't have the hardware to test it just yet, but I might be able to get hold of an extra sound card tomorrow from a friend. Also, I think my video card might be frying, as I notice on the upper right-hand of the monitor, any icons or text seem to have a red halo around them. Also, there is a red halo-ish type line running halfway down the right-hand side of the monitor.
So far, am I right in assuming both my sound card and my video card are done for??
**UPDATE**
Well, it looks as though I might need to finally splurge and get new parts I'm afraid, despite what my budget really tells me :(
From working on my computer tonight, it appears that the sound card I got off a friend might either be DOA, or there is something wrong with my motherboard. When I plug the sound card into the computer (I used 2 different PCI slots thus far), the computer slows down, artifacts through the graphics card, and doesn't recognize the sound card AT ALL. I also lost use of the internet, meaning for some reason, my NIC was not responding whatsoever (the NIC is a 3Com EtherLink XL 10/100 PCI TX NIC (3C905B-TX)). I took the sound card out, and voila, everything is back to "normal" :confused:
Also, the graphics card, I felt the GPU area, and it is HOT. I mean pretty much burning my fingers hot! :eek: The fan on the GPU is dead (not moving at all now), and I think, for some odd reason, that might be causing the sound card to bork out on me, and my internet to go bad.
I'm also thinking that my motherboard might be slowly dying? The thing is, everything else seems to work OK, but when I try to add the sound card, it just blows up at me? I haven't even tried my old sound card yet, although that might have to be the next step.
So, after this, what are my options (besides trying my old sound card)? Am I going to need to get new parts? It looks as though a new video card is the safe assumption, considering the thing is probably gonna die any minute.
Thanks!
Certainly an odd one. First off is the vid card AGP? Also, do you have any usb devices that are attached, and if so are they functioning?
Yes, I am the master of coming up with the weirdest possible computer problems, and somehow manage to fix them ;)
Anyways, the Video card is an AGP (Geforce 3, forget what brand / model exactly), and for USB devices, I have my Palm Tungsten E2, Logitech MX1000, Sony DSC-P50 digicam, and HP 656C Deskjet Printer attached, and all are working fine. Everything on the computer works to my standards when the soundcard is not plugged in, but once I get the sound card in there, I lose my internet, my graphics go a little off kilter, and depending on what sound card I have in there, I get either nothing, or a high-pitched feedback-like sound coming from teh speakers (Altec Lansing 2.1 speakers).
Well then we know the Soundcard is toast. The northbridge is functioning ok, because usb is up and running. So I would simply say you have a bad soundcard. I have seen bad PCI cards cause a machine to not even post, pull them out and away it goes. Why are you worried about your mobo if everything is ok without the soundcard?
Eh, I get a bit edgy when it comes to these types of things. I know what I'm doing, for the most part, I have done alot of system builds over the years, but when it comes to problems, I like to take a look at everything. What worried me about the mobo was maybe perhaps some of the PCI slots were killed off or something. When I was putting the sound card in, I missed the slot and got the card wedged in between 2 slots, so I'm wondering if I damaged something in there.
Worse comes to worse, I'll deal with this, and just splurge on upgrades or something. I planned to budget for upgrades within the next month or 2, so this just might be the incentive to finally do something.
Anyways, I'll update once I try the original soundcard.
Ya I wouldn't worry to much about the PCIs until further testing. You did check for swelled caps too right? That would be my only other concern.
No, I did not check for any swelled caps, but that is a good point right there, and I will check now...
.... after checking the caps, no, the caps on the mobo are not swelled, or any way affected.
But anyways, my update with the original soundcard. I plugged it in, and everything works fine, just as if the card wasn't there in the first place :confused: ...
.... but the bad news is, the card is not detectable whatsoever by any type of driver install that I just downloaded.
So here I am now saying WTF??? I mean, first the soundcard gives off this feedback, so I swap it out for another card, which seems to be dead, and now I switched back to my old card, and that too seems dead, but doesn't affect my computer in any negative way.
- Could it be my mobo is frying?
- Could it just be a coincidence I have 2 dead cards on my hands?
- Could it be because of the video card pretty much overheating and causing this?
WTF???? :confused:
Does the card even detect when you plug it in? Any other devices in Device Manager? Any indication that PnP sees it?
None whatsoever. I still have the old sound card in there, I turned my computer on this morning, acted as though it was not there.
Ok, my next question , is your NIC in a PCI or is it integrated? You could indeed have a PCI bus issue.
NIC is in a PCI slot, right above where the sound card originally goes. Those are the only 2 PCI cards I have, the video card is AGP as I said before.
I haven't tried the sound card in another PCI slot yet though. If that fails, are there any other options I have? I won't be able to work on my computer until later tonight when I get home, so anything you can come up with (or if anyone else has any input), that would be great!
Thanks!
Man, this is an odd one.
So the NIC constantly works. So I guess we can rule out PCI bus issue, cause we have at least one working PCI. Try that SC in another slot, and see what happens. Also we can rule out a goofy grounding issue because you haven't moved the mobo lately right?
Also I know this will sound crazy but, is it at all possible we are dealing with simply 2 bad soundcards? 1 goes goofy so you pull it, and accidentally smoke the 2nd one testing? I know its a longshot, but I have done it before and beat my head till I tried a 3rd.
Maybe also you could use a 3rd PCI dev, or even your nic to test each slot, to verify its operation.
I will definitely try the sound card and see if I can get it to recognize in another slot. If anything, I will see if I can get a cheap-ass SoundBlaster 16 PCI from the mom/pop store around me.
I'm a wee bit sketchy with moving the NIC around, I don't want to see that go bad on me either (knowing my luck :eek: ). I'll see what I can work on with this thing.
Let me know, I'm really curious.
**UPDATE**
The sound card is working again!!! :D
I just plugged the sound card into another PCI slot (one right above the NIC), and it works as if nothing happened :confused:
So I guess I'm all set from here. However, looks as though I will be purchasing some upgrades in the future to get this computer up to today's technology.
I'll leave this open for now if Rich Tate has any final comments on my odd problems ;)
.... and just when I thought my problems were done.... WTF?!?!?! :mad:
I left my computer for a few minutes to go check on the progress on my roommate's computer (reformat/reinstall), come back, turn on Radio Paradise, and I was back to square one... high-pitched noises again...
I reboot the computer, everything is normal again....
So, is my computer just going bonkers??
Yes, it does indeed sound as though your machine has gone insane.
This high pitched noise, just starts out of nowhere? Do you have a mic hooked up?
Nope, no mic. Just the 2.1 speakers.
I just tuned in RP, and it works fine again . I'm not even sure what the hell is going on, all I know is right now, I'm awaiting the video card to finally burn out (fan is completely dead).
There isn't a chance you have something software muckin up the works? The inconsistancy on this one with multiple cards is just astounding.
Your telling me :eek:
To answer your question: not that I know of. As a matter of fact, I have not installed any new software anytime since I last rebuilt the HD up until now. The only thing I did to the computer was put in that PCI bus fan. I'm wondering, would it be that the fan started giving the PSU stress and caused a bit of hysteria in my box?
Speaking of which, I just turned my PC on, and got the nice feedback sound... again :mad:
I am honestly considering trying to save for new PC upgrades (mobo with onboard sound, new RAM, chip, PSU and graphics card), and just deal with this one until I get the money. Tax season isn't that far away, not to mention christmas, so I'm wondering if I could pull it off somehow.
Well you could have surely put to much load of your power supply. I just don't get the noise, I have never seen a soundcard do that. The sound just starts at random? Or is it something specific that gets it going?
Not fully sure. Let me reboot and see if that helps anything...
AFTER REBOOT: Nada, same ole thing. Its a high-pitched "buzz" or feedback-like sound that comes through the speakers.
I honestly feel the PCI fan has something to do with this, considering none of these problems came until after I put that thing in. Although I'm finding it rather hard to believe that a 350W power supply can get taxed after something as menial as a fan, even with a CPU, mobo, 2 CD drives, 2 Hard Drives, a video card, a NIC and a Sound Card, and 2 case fans is all thats in the computer.
I'm gravely considering going the upgrade route, considering this computer is 5 years old, are 2nd hand parts, and seems as though its crumbling apart.
Have you pulled out that fan to make sure it's not causing some bizarre issue?
Rich Tate said:
Man Jason, I'm really out of ideas here :(
Your telling me. I think I'm just gonna start saving now and get some new hardware. I already have a list (see the "Holy.. got approved" thread) of stuff that I would like to buy. I'm done trying to work on this machine. :(
I'm sorry I couldn't help you, drives me nuts when I can't get a machine fixed :(
No worries bro, you did what you could. I've already made up my mind, I'm gonna live with this and when the tax returns rolls in, I'm gonna buy new stuff.
Time to lock this and watch it sink.
Thanks for your help :)
Status
