well if u guys have looked at my old thread .. basically my system was running all fine and dandy lol .. when i switched from 2x512mb of gskill le's to 2x1gb crucial ballistix .. all i did was swap them in .. just changed the timing to 3-3-3-8 .. the voltage was at 2.9 .. no problems .. system ran great for 2-3 weeks .. then my system crashed .. always has happened from time to time with windows for some reason .. so as my system reboots .. i boot into the bios .. 6-23 is what i was running .. after seeing how most people are running their crucial ballistix at 2.6-2.7 .. i decided to lower mine to 2.7 ... after that ..havent successfully booted at all ...
sometimes it will post so i can go into the bios .. i load optimized defaults .. reboot .. and then all the leds pass except for the last one which is what it should be .. but i get no video .. just hangs .. then if i power down and power back on .. it will have 3 leds lit up .. which is memory and will give a long beep .. over and over ..
another time i had it boot up and hang at 2 leds .. which is video .. i have reseated the video card .. etc .. i know the video card should be ok ..
originally i thought my motherboard bit the dust .. so i got another sli-dr board .. just to check .. same problem .. when i first connected everything up ..it booted right to the bios .. i loaded optimized defaults and BAM .. same thing .. i rebooted and the monitor just goes black .. u know what i mean .. like when u shut the pc off but leave the monitor on .. then if i power down .. and try to repower back on .. 3 leds with that long beep over and over .. it really sucks and is driving me mad .. im having pc withdrawal ... i dont have any other memory to swap in ..
