Problems overclocking 2500 barton
GOD'SlittleSERVANT said:
i try from the bios but it always restarts. Hmmmm anyone got any suggestions?
restarts? As in resets back to default?
are you trying to just adjust the multiplier, because that will happen, it's just not capable of certain multipliers.
didnt know that.. i ran 10-14 just fine.. even done 6(also includes all the .5's inbetween 10-14)
I have a 2500 and a DFi LP NF2UB and it's running stock....gasp!!! However...I have Oced these things before and depending on the mobo, the multiplier can be set downwards...ultimately, you should be running 200fsb with 10x or greater multiplier and 1:1 3200 ram! Get the kind LL stuffs from OCZ, Mushkin or Corsair.
Peace!
Also...reboots could also come becuase you are not upiing voltage, or just that your mobo sucks arse!
M
Old bartons are unlocked ... new bartons are locked ... you'res is probably locked (aka you can use lower mult. but not higher).
