steven1110
- Aug 12, 2004
I just bought a new computer (specs below) and started to install windows for the first time. At first it kept getting stuck at the first windows setup screen, getting to various points in the loading and then bringing up a screen that read IRQL_NOT_LESS_OR-EQUAL. So I restart. It did this a few times so I transferred in a different dvd drive.
Windows setup then got to the copying file portion and would get to various files and say that they couldn't be copied..push enter to try again or esc to skip. Pushed enter and finally got past only to get stuck again. It did this about 10 times throughout 80% of the copy setup only to then give me another blue screen saying to possibly check the hard drive for corruption. I haven't done this because I don't know how to get into a dos mode from the mobo splash screen. Anybody?
Any ideas on what to do or about what may be causing the issues??
AM2 4200 2.2ghz with 512 cache
Western Digital Caviar SE16 WD2500KS 250GB Serial ATA II 7200RPM Hard Drive w/16MB Buffer
MSI K9N SLI Platinum nForce 570 SLI
OCZ OCZ520ADJSLI PowerStream 520W
BFG GeForce 7900 GTX PCI Express 512MB GDDR3
OCZ OCZ28002048ELDCGE-K 2GB Kit DDR2-800 PC2-6400 Enhanced Latency Gold Edition Dual Channel Memory
