Im trying to get the 9700 heatsink mounted onto a core 2 duo. The problem I'm having is that when I try to screw it down its damn near impossible to screw both screws into the bracket.
More specificly I dont think that the screws are long enough. The instructions both on the layout and on the zalman website both illustrate that you should alternate while tightening the two screws, but this is almost impossible since the holes for the screws on the bracket is large enough for them to just move in and out (which gives me a see-saw action when I try this), and secondly there is a hex nut on the bottom, which when reached is srtrong enough to hold the screw in place but its very hard to force the other screw into the hole (since by now there is alot of tension on the bar and I dont know ho much pressure I can/want to put on the motherboard trying to force it down there).
I was thinking that a longer screw might be a solution since I wouldnt have quite a see-saw action if two longer screws could reach that hex nut on the bottom, then I could tighten both in an alternating fashion like in the instructions (but then I would need to find some other screws, and I have no idea where to start).
Anyway thats my problem in a nutshell. I thought I might post it here and see if anyone else has had any similar experiance.
