Problems installing WD Raptor 74 GB 10k
A little background info: I recently had my WD 80 GB 72K hard drive crash on my irrepairably, and so I decided to buy a new hard drive, as well as get a new version of XP Pro. I went to New Egg as I have always had excellent experiences with them before. I ordered the WD 74 GB Raptor 10000 SATA. THe specs for my computer are:
P4 2.8 HT CPU
ABIT IS7 mobo
ATI Radeon 9800 Pro
1 GB DDR Kingston RAM
Audigy 2 soundcard
Plextor DL DVD+R/DVD+-R/RW
I plugged in the HD to my computer, plugged in a power connector and then attached the SATA cable to the SATA1 port on my mobo. I bought the WIndows XP Pro OEM os from New Egg, and I put that in optical drive to try and install everything. Unfortunately, when i choose to run Windows Xp and install it, I receive a message that says
"Setup did not find any hard disk drives installed on your computer. Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk related hardware configuration is correct. This may involve running a manufacturer supplied diagnostic or setup program"
I only bought the OEM version of the drive, so it did not come with any cd. I know it is plugged in so thats not it. I went to ABIT's site and dl a driver for having a SATA HD and installed it by hitting f6 during the windows startup, before it goes to the setup menu. I am utterly clueless as to what to do. ANy help would be greatly appreciated.
did you verify that the computer detected the presence of the new hdd (go into cmos setup)? i don't have any experience with SATA drives but do they need to be jumpered in any way?
sata dont usually need to have jumpers. atleast in my case they have never needed to be
So did you hit F6 and then when it prompted for you to insert the disk did you?
Usually it works this way. You make a diskette with the SATA drivers on it. Upon boot insert the diskette and boot off of the WinXP CD. Hit F6 when asked. It should prompt in the middle of copying preliminary files to select additional devices by hitting the S key. Do so and it should show the drivers that are on the diskette. If there are more than one then hit S again until all are shown. Once all are copied then hit Enter to continue. WinXP should now see the drive.
Thats for RAID, not sata drives. Just go into bios and make sure its set as the primary hdd drive and that its detected, simple as that. Then set CD drive to first load and boot the system and windows setup will find it.
If it doesnt, check that your sata ports are activated on your motherboard. If that doesnt work i'd begin to worry about if your sata ports actually work at all :(
F6 is to install any driver for any storage device that you want to install WinXP on. If the WinXP setup disk does not have the correct SATA driver for the SATA controller, it will not recognize the drive.
You most likely do not have SATA enabled on your motherboard. Check that and let us know.
I had enabled the onchip SATA in my mobo. I am wondering if my previously having an IDE HDD before may have done something, im not sure.
You will want to try out what he sais, I pretty much gaurantee if you think F6 is for raid only then thats your problem
I did that and put on those drivers, thinking that anything with a sata controller, raid or no raid, might help, but still no go. I installed both the Abit drivers (listed above) and the WD sata controller drivers. Any possibility the Abit IS7 mobo is bad and wont recognize any sata drives? its about 2 years old and this is my first attempt at using SATA
