Problems installing/using new hd enclosure with new oem drive
yellafella321
I recently picked up a new wd. 200jb oem hd along with a bytecc 3.5" external subsystem.
I plug it in, get the click, get the error that says that its not hooked up to a high speed usb device like with my other external hard drive, but then no detection of the drive whatsoever, what did I not do/do wrong?
First thought would be to check jumpers. Most ext enclosures require the drive to be set as master. WD's are picky in that respect. They have a master with slave setting and a master only setting which i think is no jumpers. Double check that though ;)
If that's not the problem it could be a bum drive (try it on an IDE port in a system) or a bum enclosure. I've seen it happen all 3 ways.
Also is it partitioned? If it shows up in device manager but not "my computer", go to disk managment and partiton it.
==>Lazn
