Problems installing things with WinXP
I have this strange problem where I can't install a program if it is above a certain filesize. After installing about 30mb of a program, the installer locks. When I tell the task manager to end the task, XP completely locks and I have to do a hard reset.
To isolate the problem, I have tried installing to a different hard drive, installing varied programs, installing from a cd (instead of off the hard drive), running a program called windows installer cleanup, and installing on a different XP account. None of these worked.
When I went to the folder where the 30mb or so that was installed resides, I get a CRC error on all of the data. I have tried searching google for ideas on what is wrong, but I am having trouble finding anything that relates to my specific issue. Hopefully someone in this community can.
My setup is XP Pro w/ SP2, AMD Athlon 64 processor, a maxtor 160gb hard drive, and an Asus A8n Sli-Deluxe (nforce4). [Edit: I have plenty of free space on my drives]
Thanks.
Sorry about the bump, but if anyone could help please do...
Otherwise, I shall resign myself to reformat death.
Have you tried running the manufacturers utility for the HDD to check if it is health of the drive giving you issues.
CRC= Cyclic Redundancey Check
Reason I ask is a customer of mine just picked up a brand spankin new Seagate 160gig Sata 5 year warranty drive.After first format and install of Windows XP .Speedfan came up in the smart section saying drive health down to 34% .WTF.What a POS.
I stay away from Seagates now.
I'm not saying all Seagates are bad just this one and the 4 others with similar story's.All 160 Gigers.Go figer.Hump.
$0.02
MassRaptor
Maybe because it's a Maxtor? lol, j/k. But in all seriousness, have you run a CHKDSK? You should check the health or get some drive diagnostic tools. That's what I would do anyway. Post on how it turns out, I'd like to know. Good luck! :D
