I guess I should have known better and back up my files before attempting to do this but I guess the virtue of being patient did not go well with me. Before I go on a crazy rant, let me post my specs and give you a brief problem of what I am going through in hopes that you guys can get me out of the rut I am in right now.
Ultra Aluminus Case w/2 120mm fans
EVGA 680i SLI motherboard
OCZ 2GB SLI 1066mhz Ram
Intel E6300 @ 2.8ghz w/AC7 Pro HS
ECS 8800GT w/Accellero S1 OC'd @ 700/1000 Driver 177.83
Samsung 700 SATA HDD
Thermaltake 600w PSU
Everything was working fine until I decided to upgrade to the new 9.64 nForce drivers (i had the most recent but previous to this one). Installation began smoothly but Spybot Teatimer kicked in when all the changes started to occur so I exited Teatimer and Avast just to be safe (in the middle of the installation though, I know, that was stupid, should have done this prior), and even though it finished, I did the installation again, just to be in the safe side that neither the Teatimer or Avast had interfere with the previous installation.
Towards the end of the installation it told me that it had detected some other drivers and that it need it to uninstall those but it would continue with the setup once Windows had restarted. It started with the rebooting and right after the Windows Splash Screen, it faded to black (it always does this before it gets to the login screen). I went outside to smoke a cigarette and when I came back I was very surprised to see the screen was still black and it never got to the login screen.
This has happened a few times before and a quick hit of the Restart button gets it going again but not this time. I'd figure that it was probably doing some of the installation on the background before getting to the login screen so I left there for a long while and went to do other things... came back, turned the computer off, tried again to no avail.
This morning I tried going into Safe mode but as soon as I get to the login screen the mouse and keyboard are locked, I even tried turning it off, plugin in an old PS2 mouse but that didn't work either.
I went as far as to go back into the BIOS and setting it back to its default settings thinking that the OC'ng maybe had something to do with it... Nothing.
Tried inserting the Windows XP cd to try to repair it from DOS but it tells me that it can't read my C drive (perhaps because it is a SATA drive?).
I know the system files are ok because it does the self test post ok and it gets up to the Splash screen. I went as far as to creat a Restore Point prior to attempting this update but I can't get to it.
Can you guys give me a few more ideas? even though, a solution would be much much better
