I'm installing an Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 - Retail - 280$ in an ABIT IP35-E LGA 775 Intel P35 ATX Intel Motherboard - Retail - 119$ as my first time ever assembling a self built pc and I'm running into several problems with the processor and fan.
The first problem was while pressing down the latch on the cpu. After making sure the notches were correctly lined up I still had to press down VERY hard to get the arm down, almost like it was in the wrong way. I double checked twice before finally forcing it down to make sure the notches were lined up but judging from the pins it didnt look like the QQ6600 and P-35 were even a match because the male and female grooves looked nothing alike, not sure if this is normal.
The second thing that worried me the 4th pin of the fan ABSOLUTLEY would NOT go down. I applied extreme force to the point I thought any harder I would damage the motherboard.
The third problem I ran into was I put the fan over the processor right away and fastened 3 pins down and forgot to apply the Arctic Silver. I tried to remove the fan but the 3 pins seemed locked into place I can't figure out how to remove them.
I need advice how to get the fan back up and and what else I am doing wrong
