corey2024 said:i have a laptop and on it i can hard wire the internet or do wireless and either way it connects, gets an ip address and everythign it needs, but yet i still can't connect to the internet, any suggestions
corey2024 said:command prompt - ping www.google.com
the NTVDM CPU had encountered an illegal instruction.
Cs:055c IP:0102 OPf 04 30 3c 39 Choose 'close' to terminate the application
Rick \Nutcase\ Rogers wrote:
> *Hi,
> Close all running programs. Locate ntvdm.exe and wowexec.exe in the
> \Windows\System32 folder and delete them (one or both are probably
> corrupt).
> Reboot the system. See if the problem goes away, as the files will
> be
> replaced by ones from the system cache (System File Protection at
> work).
I would first try expanding those files from the \i386 folder on the
windows cd onto the ones you have in your \system32 folder it will
replace them with the original ones. This way is probably a lot easier
than deleting and restarting and such.
open up a command prompt (start-->run-->"cmd"-->enter)
then enter the command as follows where D:\ is the drive letter of your
cd drive.
Code:
expand D:\i386\ntvdm.ex_ C:\windows\system32\ntvdm.exe
Do that for the other file too.
If you ever have this sort of thing happen to you while trying to use
ping, go into the system32 folder and delete ping.com
