Okay, I'm having a problem with my computer. I built it about ten months back, and it's been acting up recently.
90% of the time it won't boot up. When I can get it up and running it runs perfectly fine as long as I don't try to reset or shut down. Once I try to reboot, when the problem occurs, the PC itself does turn on-- the fans spin up, all the LEDs in the case turn on, so it looks like everything is getting power... but nothing comes on the screen. No signal whatsoever to the monitor. The odd thing is that even though the fans and such power on, most of the time the USB devices (external HDD and mouse) don't have power running to them. When it does work fine, those devices seem to get power immediately.
Even when the thing boots, it's choppy during the POST sequence... During the memory test it will hang, so that it looks like "Memory tes" on the screen for several seconds... and then the rest will appear-- "Memory testing blah blah blah".
I don't really have spare parts to swap in and out, so this is difficult for me to troubleshoot. Do you guys have any ideas? I hate having no idea whether or not I'll be able to get my computer back on each time I need to reboot it.
The symptoms are kinda all over the place, so I'm not sure which component is to blame. I thought it might be the PSU, but I'm using a 550w Gigabyte Odin GT, and I know that those things are extremely efficient... so it seems like it should be enough power. The fact that the USB devices don't always receive power though is concerning... then again, the fact that it hangs on the memory test makes me think it might be the RAM... and the lack of signal makes me think it might be the GPU... and any one of these things could mean it's the mobo or something.
So yeah... I'm kinda upset about it. I'm going to remedy the problem, but before I start buying replacement parts I need to know what needs replacing. =/
Any ideas? Thanks in advance....
