superlyduper
- Jun 7, 2004
So I physically moved my computer about 3 feet, heard some screws rattling around (happens all the time, there are some loose screws inside the case), and tried to boot anyway. I get to the bios splash screen (it says hp, and has option for boot menu, setup, etc). If I press fast enough, if I press the key for one of the options, it will say "loading boot menu", or "loading setup", but it will stay like that forever. If I don't press a key for one of the options right away, nothing happens when I press a key later on. I've tried both onboard graphics and my nvidia card, i've swapped out the ram for ram I know is good, i've tried booting with just cd and with just hd (my data is still intact, whew...), i've reseated the cpu/heatsink (although unfortunately I don't have access to another cpu). i've tried using the jumper to clear the bios/cmos settings, to no avail. I've looked a bit through the manual, but haven't found anything interesting..
Here is my equipment
MSI-7903 (ATI S480M2-IL) I ripped from a HP computer
athlon 64 3500+
geforce 7600gs
alot of ddr1
Is there anything else I can do? What might be the problem?
athlon 64 3500+
geforce 7600gs
alot of ddr1
